I see there is a new version of the Smith3D firmware, couldn’t find anything about bug fixes or other information on it. Anyone tried it or know what’s different?
Guess I didn’t look hard enough found this
[TABLE="class: highlight tab-size js-file-line-container"]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 19-12-2020 [V2.0.X.16][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Many marlin bug fixes[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (19-12-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"] [/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 20-11-2020 [V2.0.X.15][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Clean up codes warning (Credit to to NickDevoctomy)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Marlin bug fix (live z offset adjustment)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (20-11-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 13-10-2020 [V2.0.X.14][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Delete plr when cancelling resume print[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Improve Refuel feature (faster feed rate 150mm/s)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Marlin bug fix (Stop print will now stop properly)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (12-10-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 02-10-2020 [V2.0.X.13][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Resume Printing is now working properly[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Support MicroSD card extension cable (no longer need to reseat extension or restart printer)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Default Refuel mm to 10mm[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Enable #define ENDSTOPPULLUPS (Credit to to Dimitris)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Prevent changes of zoffset when just turning the knob during live[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Adding more precompiled firmwares for Filament Sensor & 4.2.7 Mobo[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (02-10-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 21-9-2020 [V2.0.X.12][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-English on boot[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (21-09-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 19-9-2020 [V2.0.X.10~11] - allow estep over 186[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Bug fixes for Z offset tools (much better accuracy)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Allow E-step over 186, up to 850[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (18-09-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Added Advance Refuel Menu for Filament Retract & Feed[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 8-9-2020 [V2.0.X.9] - Filename longer than 22 chars[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Fixed issue where print resume cancel does not cancel the print[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated to the latest Marlin (08-09-2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Support filename that is longer than 20 characters.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 16-8-2020 [V2.0.X.8] - Z-Tool Offset Bug Fixes[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Enabled BLTouch High Speed Mode (Experimental)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Enabled BLTOUCH_HS_MODE (in configuration_adv.h)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Adjusted Z_CLEARANCE_MULTI_PROBE to 2[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-HOMING_FEEDRATE_Z bumped from 4*60 to 6*60[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 13-8-2020 [V2.0.X.7] - Z-Tool Offset Bug Fixes[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Fixed issue where Z-offset tool may not reflect the actual z changes when adjusting real-time[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Added "Re-Home Z" button in Z-offset tool so user can make changes and test real Z immediately.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-It's very important to heat up nozzle to 180-200 while using Z-offset Tool (if there is PLA in nozzle) Else the Z-offset will vary a lot depending on the leftover material stuck on nozzle tip.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Enabled ADVANCED_PAUSE_FEATURE[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 1-8-2020 [V2.0.X.6B] - Major Update.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated BLTouch to use 5 pins port provided by the board. Replacing Z Stop Switch is no longer required. (If you still have your old wiring done based on our older guide you will need to change it in order to flash 2.0.x.6 firmware) We believe this is a step forward as it gives you the flexibility to switch to other firmware without the hassle of changing the wiring.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-EEPROM is now saved within the board instead of SD card.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Changing Z-offset now works when printing. Will be reflected immediately. Store configuration if you want it to be persistent across reboots.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Pausing works on the printer now. Which means file like CHEP's leveling gcode will work.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Added white borders to Tune/Pause/Stop buttons[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Improved Z Offset tool (Remember to pre-heat your nozzle while using this as any remaining material stuck on nozzle tip might interfere with the result when you gauge with A4 paper)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Corrected most labels and typos in DWIN UI[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Updated Marlin to the latest build (1st August 2020)[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 28-7-2020 [V2.0.X.5][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Fixed AUX Leveling Bug and added support for M48 command.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Adjusted XY speed to be a little bit faster when auto-leveling[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Updated 25-7-2020 [V2.0.X.4][/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Adjusted max bed size back to 220 as some users are facing issue where it's printing outside of edge.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]-Previous version was using value of 220 + 15 as it helps BLTouch to probe nearer to edge for better mesh output.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Internal Reference[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define FILAMENT_RUNOUT_SENSOR[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define NOZZLE_TO_PROBE_OFFSET[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define BLTOUCH_HS_MODE[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define GRID_MAX_POINTS_X[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define X_BED_SIZE[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]//For Standard Filament Runout Sensor[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define FIL_RUNOUT_STATE HIGH[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]//For BTT Filament Smart Sensor[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define FIL_RUNOUT_STATE LOW[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define FILAMENT_RUNOUT_DISTANCE_MM 7[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define FILAMENT_MOTION_SENSOR[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]//For RaspBerry BTT[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define HOST_ACTION_COMMANDS[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]#define HOST_PROMPT_SUPPORT[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[TD="class: blob-code blob-code-inner js-file-line"]Change: #define MOTHERBOARD BOARD_CREALITY_V4[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
To: #define MOTHERBOARD BOARD_CREALITY_V427
Yea been using it for a while now haven’t seen a lot of differences.
They say bug fixes. Not seeing very many.
