Petg, ahhhhh
Hi all, been printing pla, no problem at all, been very pleased with my Ender 3 v2, now I’ve switched to petg, well I can’t get them to stick, tryed all types off settings I’ve got off the net, tryed painters blue tape, magigoo, doing something wrong, the filament is sunlu, would appreciate what settings you guys are using, many thanks Andy
Be sure to level the bed again, then print a 1-layer 20mmX20mm square, using diagonal fill lines. If the lines are separate, as I suspect they might be, set your Z Offset more negative, in .05mm increments (if supported). Try a bed temp of 80C.
For PETG I’m using 235C/70C-80C.
I’ll give it a go thank you
