I’ll start with a little history wanted to give the granddaughter and her new hubby something special as a remembrance of the happy day. Ran some ideas through my head and came up with a heat with 3 hearts in the center, there is a great granddaughter involved in this too. Took the design from my head to Freecad after a couple of tries I got it were I was happy with it. My 1st attempt at printing the letters would not stick, as you’ll see each heart has the name of the people involved. That turned out to be the filament I was using. Using a filament that I have good luck with the letters were fine so not a design issue. Scrapped that filament and went with a known good printing filament, it’s COEX Pla but I don’t think the filament is the issue.
Now the problem when I print this I get a line in the left of the outside heart and a line through the left & top inter hearts. The right heart doesn’t appear to have any artifacts in it. At 1st I was printing at 0.10mm with a 4mm nozzle. Thought maybe because it wasn’t a multiple of 4 could be the issue so I switched to 0.12mm with the same results which is what the photo below was printed at. It was sliced in Prusa Slicer 2.5.0 getting the same results on both the S1 Pro & S1 Plus thinking maybe it’s a printer issue. Both the view in Freecad and the sliced version in PS do not show these strange lines. I’m at a loss as what is causing this.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG_3707.jpg Views: 0 Size: 3.60 MB ID: 16645”,“data-align”:“none”,“data-attachmentid”:“16645”,“data-size”:“full”}[/ATTACH]
