I recently purchased a Prusa i3 MK3S+ and loving it, nearly used up a whole roll of filament already.
I’m on the upgrade trail. I built an enclosure using the “lack table” method, the prints turned out extremely well.
I’m looking at adding a temperature sensor, I purchased a DHT11 and have tested it using a python script in the terminal of my Raspberry Pi 3B+ and it works correctly.
I’m trying to enable it in the Enclosure Plugin, but the temperature is not registering. I know that the plugin is depreciated, so if anyone can recommend an alternative, that would be gratefully appreciated.
Also, I’m using the USB Relay Plugin to drive power, lights, etc. I tried OctoRelay, but it prevents my touch screen from responding.
If anyone knows how to automate devices connected by USB Relay, that would be wonderful ??? .
My problem is that my printer is located in the attic. In Ireland, the temperature overnight can get low enough that the printer shuts down and refuses to co-operate until the enclosure is warmed up.
I think I will go with a low tech solution, as suggested by another user - use a room thermostat to control the heat pad I purchased, that will heat the enclosure sufficiently before printing. Problem solved.?
I was looking for an automated solution, but sometimes simple is best.
