My Ender 3 pro has only an 8 bit card and I have version 1.1.9.1 recently downloaded from TH3D site. I was hoping that it would be able to read Prusa’s M600 command but it doesn’t seem to.
I do not want to go through the hassle and expense of installing a 32 bit card at this time but I would love to have a script that my version of Marlin can read so I can play with colour and filament
type changes. Can anyone point me in the right direction? Thank you in advance. I can do it in CURA with their method but I just want to use one slicer. I need to be able to do it easily in Prusa.
I opened the g code of a CHEP yyz cube that I tried to filament change in Prusa to see where the M600 command came in but I couldn’t find it and I don’t seem to have any search capability on this
Macbook utility. I was thinking about doing the same thing in CURA and extrapolating the G code but I need a text editor with a search feature. Maybe I will wait for my geek friend to come over.
Maybe IO will try to get him to go into Arduino and activate the M600 command and recompile everything to see if that works. I can never get Arduino to compile.I am worried that my 8 bit board
It doesn’t use M600 as I remember from the distant past. It runs a script my Marlin can understand somehow. I think it runs a ‘pause’ command and then the script to dock the print head beep a signal and then start cooling down. It gives instructions and I think I could even reheat the nozzle and start it again.
I get confused enough using one slicer and I just don’t like CURA for some reason. I think Irv had a video showing the different ways to change filament in Prusa and in CURA so I tried both. CURA’s method is much more clunky. I want to be able to use Prusa’s method.
