I decided to get the Creality Sonic pad to move my printing into the klipper arena. After I installed it and went through a dozen you tube videos on how to set it up, I am finally printing. Creality offers a set of Cura profiles, they have a slicer based off of Cura, to make the transition easier. The have two profiles for common filament options for normal printing and fast printing. I thought I should start with what they call normal so I am using a profile for my specific printer and PETG.
Bufore I printed I cleaned the hot end and changed the nozzle to a new stainless nozzle.
To get started I made a small block 30mm x 30mm and using the normal profile, I assumed this profile has given good results at the factory, and printed it.
After I printed the first 10 layers of the print I stopped the print and the above was the result. I took the cover off of the nozzle/hot end to see if some filament was leaking and could not see any.
I will do more testing to see if I can see what is causing this, first will lower the infill speed.
Any suggestions for why these drops are here would be appreciated. I have read that they caused by over extruding. I did a test, from a youtube video, and it seems to be correct. I will lower it if it gets to that.
Edit:
I did a bunch of tests at different speeds and different extrusion setting and the following two images seem like the best so far. I guess I could go lower in speed. The question for now is, are these sufficient until I figure it out better, after all it is only infill. The part that I am currently working on does not have a torque to worry about.
The image on the left is at 65 m/s and on the right is 75 m/s infill speed. I could probably go to 85 m/s with little difference.
I still need to better understand what causes this, any suggestions would be appreciated.
Could a better nozzle help out? I use the ones from Creality but have seen E3D X nozzles and some for close to $100. Microswiss CM2 are also in the $20 price range? Anyone use any of these?
