Hi Irv
I follwed your guide on setting e-steps on a 3d printer.
My problem is that on the JG Master Artiste D pro you have two extruders but only one setting under motors!
I used your method of marking out 120mm of filament and then extruding 100mm and measuring the remainder. On extruder 1 it extruded only 92mm and extruder 2 extruded 85mm of standard PLA @ 200 degrees!
Any advice
Regards Kitsoft
