You are not more perplexed about what is going on than I am. I have been using a lot of Ereone filament because it is fantastic. Wghen it works it is so beautiful.
I think your filament has absorbed too much water (my emphasis added):
"The main reason for brittleness of filament is due to moisture absorption. ABS, PLA, and other common filament materials are mildly hygroscopic, so they will readily absorb moisture from the air. This is especially true if you live in a humid environment.
Symptoms
Below are the some of the most common symptoms that your filament has absorbed some moisture.
[B]Brittle and break easily[/B]
[B]PLA filament swell and cause your hot end to jam. In worst case jams require hot end replacement.[/B]
Trapped moisture inside the PLA filament, becomes stream inside hotend which then interfere with the flow of plastic
Printed objects are weak
Makes a rough/grainy surface on finished prints
Filament is making a popping/cracking/hissing sound
If your filament is making a popping/cracking/hissing sound, or makes a rough/grainy surface on finished prints, your filament has probably absorbed some moisture. ABS, PLA, and other common filament materials are mildly hygroscopic, so they will readily absorb moisture from the air. This is especially true if you live in a humid environment." (Full article here.)
I have 3 rolls of ereyone in gold silver and copper ‘silk’ and Geektech white and a roll of Geektech black. I usually print at 305 or 210 C. Creality ender 3 pro stock extruder. I have an upgraded. LEOWAY Ender3 Upgraded Replacement Dual Extrusion, Aluminum Dual Gear Extruder Upgrade Kit.
All of them are giving similar results. I’m beginning to think it will be better when I update my Marlin. I just successfully printed the same cable chain link that failed yesterday so I decided to print another and twice in a row it gave me an error message. Heating failed please reset printer. Now it is printing again. I am waiting on TH3D to get back to me on my arduino error message so I can flash my board.
I just relized that I was wrong when I said that it successfully printed the cable chain link. I just didn’t notice that it had been printing in the air before it finished. Again the print is quite beautiful with perfect layers until it suddenly plugs and quits laying down plastic. I am going to try it again and see if the heat shuts off by watching the nozzle temperature.
I’m doing another link in Geektec white and I put a brand new nozzle on. It’s really boring watching the nozzle go round and round waiting for it to fail. I think my printer has brain damage just like me.
Something interesting happened, the link printed beautifully till the end and I selected it again on the TF card and got heating failed please reset printer twice in a row so I let it sit for awhile and I am just now trying this again.It seems to be starting filament is coming out, let’s see if it prints now.
The second link started out ok so I turned my back on it and the nozzle clogged again so it was waving around in the air when I looked back. I forgot to check the nozzle temperature like an idiot.
I am not getting any plastic at all oozing out at the nozzle. This is what I did for my nozzle with a variation, Simple HOTEND FIX for Creality Ender 3, CR-10 - YouTube I couldn’t get the ring that they make to let my bowden connection screw in. But it seems quite good. I do get this (as per supplied photo)
I take off the nozzle and unscrew the bowden to hotend connection. I have the plastic jammed way up the bowden so I either push or pull or both to get it out of the bowden. I can unscrew the nozzle usually without heating. The plugging seems to be way up there and the spiral indentations you see are really spiral. I do wonder if I have amazing 'heat creep, but the fan is working.
I’ve seen that video before. I believe you said you didn’t include the compression ring that he put in. I assume you did install the compression fitting that normally is mounted to a hotend:
