So, I was using Cura and I could never get rid of the stringing no matter what I tried and I tried everybody’s solution, well from several youtube videos anyway including Dr. Vax. So I read something about someone using Prusa Slicer instead and so I thought I would try it. I does have some issues, but after downloading a profile for my Ender 3 it I was finally able to print a string test with very little stringing. There is some, but it was significant improvement over Cura and I can live what little stringing there is now.
One thing I noticed though is that when slicing the gcode does not contain the LAYER number which octoprint uses to display layer progress. Does anyone know how to insert gcode or a script to display the layer numbers?
Did you try using the retraction distance, speed, and Retraction Extra Prime Amount settings in the Prusa profile in Cura (maybe the Prusa profile is better tuned overall?)? For one printer, I found stringing was more sensitive to print temperature that those 3 variables, fwiw.
I’ve not used Prusa slicer, so no ideas for the second question.
Yes, I tried his profiles. While it helped a little, it was not nearly as good as in Prusa Slicer. As for adding Layer information, that should be trivial. All I need to know is when the layers change. I think I know, but I was hoping I did not need to do it manually.
When I said complicated, I was referring to the idea of automating the process. It certainly would be easier doing it manually. The best option I can think of is to detect when the Z height changes.
What I did was print a temperature tower to find the best temperature with the least stringing. Then I changed the retraction settings though not all at once. This helped some, but not enough. So, I downloaded both CHEP’s and Makers Muse’s profiles and tried them, but still they did not work right. I may try the prusa settings in Cura, but right now I have it worked aside from the layer information which is not that important though it would be nice to know what layer you are on.
In Cura there is a simple feature you enable once and it show the layer and or the time left in the display. Once you sliced a model go to the menu and there is an option “post processing gcode” (or something like that). It opens a window, click on add and choose a module you want.
Same way you add pause at height etc. Once selected the option stays enabled for every slice you will do in the future, so remember when using pause at height to remove it afterwards. I have the time information always enabled, so I can see how long it will take, even if the value only gets updated at the begin of a layer.
When using OctoPrint there is an additional plugin that comes in handy. It shows the M117 command (Display message) within the browser title, so you get the same time information there, too.
There is a big number field showing the number of post processing scripts next to slice/save, so if that number is 2 or bigger you should consider checking.
