I’ve been spending a lot of time with this printer and learned the following.
I have my doubts about the Z offset setting video on the front panel. I found I have to manually level the bed, and set it quite close to the nozzle, for my prints to stick without a raft.
I replaced the bed surface with BuildTak and it really made no difference.
I tried to use various Github-provided solutions to get Cura to work with this printer with no success so far.
FlashPrint seems to have a bug that if your print has a height of less than 2mm the top surface is not properly finished. It is left very rough.
Print quality on details greater than about 3 mm is quite good but the print quality on small lettering is terrible. This might be the slicer, time will tell.
The email support from Frlashforge is quite timely. Basically 24 hours turnaround but they might be using a computer translator since the English exchange is not great.
Trying a detailed print at a .10 layer height now to see if this helps.
Tried variable layer heights in FlashPrint and found it tricky to set up.
I will report more info here as I learn it.
