Been using Freecad for a while and currently using the weekly build. Can’t remember when the problem first appeared but my cursor went from being the normal system cursor to being a fat triangle as seen in the photo. While trying to fix that some how I now have little red dots on the corners when in the 3D view, it’s the same no matter what workbench I’m using.
I use Linux so Freecad is run as an Appimage. Trying to fix the cursor issue I went and deleted all the Freecad directories I could find including the hidden ones in the Home directory. So naturally when I started I had to set everything up again. In doing so some how I turned on the little red dots the also are there no matter what workbench is being used.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“large”,“data-attachmentid”:16738}[/ATTACH]
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“large”,“data-attachmentid”:16736}[/ATTACH]
