For the past 6 to 8 months I have been happily printing on a PEI coated, spring steel sheet. It has worked very well, but a few days ago I ran into a major flaw with it. Have a look:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“custom”,“height”:“292”,“width”:“415”,“data-attachmentid”:13459}[/ATTACH] [ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:13460}[/ATTACH]
[IMG2=JSON]{“data-align”:“none”,“data-size”:“full”,“src”:“https://forum.makewithtech.com/core/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==”}[/IMG2]
When I went to check on this print, I found something I had never seen before: the print was so well stuck to the spring steel sheet (by Dimafix) that the desire of the print to warp actually pulled the spring steel sheet off the corners of the magnetic underpad, turning the steel sheet into a shallow bowl. Not surprisingly, this led to the steel sheet being rotated by the action of the hotend. The rotation is quite visible in the photos, especially in the closeup of the corner.
What to do. I had a borosilicate glass printbed in the drawer from my early days of experimenting with glass beds. It was undersized for the Ender 5 (220mm X 220mm instead of 235mm X 235mm) but still large enough to hold the print. This meant I had to go back to using binder clips, which I hate because they can interfere with movements of the printhead.
I installed the glass plate, coated it with Dimafix, and re-started the print. This time it worked perfectly. With that success, I ordered a genuine 235mm X 235mm Creality borosilicate glass plate. I also ordered some much lower profile bed clips. With it installed, and again coated with Dimafix, I printed another tray, which came out perfectly.
The only issue I had with using the glass bed is that the prints are sticking too well. They were fairly hard to remove. My plan is to gradually reduce the bed temperature, in hopes of finding a temperature that will prevent warping but also release easily.
Bottom line: I’m once again printing on a glass bed. Everything old is new again??
[SIZE=48px]?♂️[/SIZE]
