Just installed a direct drive (Micro-swiss) onto my Ender 5+ with the goal to print with higher temps. Already successfully using Micro-swiss Hot end prior using PLA (6 months).
Having problems with prints not sticking to PEI though they stuck fine prior to DD install using PLA prior. With PLA after DD install they are not sticking.
I’ve adjusted the extraction distance to 1mm using the recommended slower 27 speed. BLTouch bed level confirmed. Nice bead size. PEI cleaned with soap and water and additional 99% Isopropyl.
I would view this video and try the test square. I have found them very useful. I’ve linked the video to several other people in this forum who also seem to have found the technique useful:
[U]Best method for 3D printer bed levelling - YouTube
If you also switched to a Micro-Swiss nozzle and an all-metal hot end you will need to increase your print temperature by 5-20 degrees depending on the filament. If the filament is extruding at too low of a temperature it will not stick as well. I also upgraded an Ender 5 with the Micro-Swiss hot end and direct drive and love it. I find that using MagiGoo or Dimafix on the print surface makes everything easier. If you do not have any I would order Dimafix, it is less expensive, and you can control the stick by controlling your bed temperature. @Ender5r – I think you recommend Dimafix to me and I have not looked back.
Actually, with the install I assumed the BLTouch replacement would remain the same. What I discovered was the BLTouch was too high and I had to adjust the Z offset. Still not getting complete leveling since I can print on 2/3 of the large bed reliably.
As I posted above, I use Dimafix but, yes, I put it on PEI. I would do the same with Magigoo.
And, please, watch the video I linked to above by Hobby Hoarder on printing 30mm test squares. They are extremely useful for testing and setting bed tramming (leveling) and Z Offset.
