SKR Mini E3 V2.0
BIGTREETECH Direct SKR Mini E3 V2.0 32Bit Silent Main Board + TFT35 E3 V3.0 Integrated with TMC2209 UART
Any comments/advice on using it on a CR-10S with EZABL?
It should work fine. You’ll have to tweak the firmware for your bed size and the ezabl. I don’t know what the electronics enclosure is like specifically for the CR-10S, so that may need to modded or it might fit as is. The mini E3 is a pretty small board.
Thanks, have you used it? Will it work with a 12v system? I have yet to hear from BigTreeTech…
Check Aliexpress for specs. Looks like the board runs on either 12 or 24v. Nice features such as sensorless homing.
