OK I got the speeds about the same but need help. The photos compare a sting test sliced in Cura and PrusaSlicer along with there Gcode viewer. ASs you can see the PrusaSlicer produces better results. Micro-swiss all metal hot end and DD, temperature and speeds and retraction setting are the same (200 deg PLA 1mm at 45mm/s. The other stringing photo is sliced in Cura at the same settings. not perfect but much better. The results lead me to believe that the point of retraction and detraction leads to the discrepancies in the stringing and the effect is only noticeable when the tower is very thin. The results suggest that there is a difference between the two but I have idea what this is, any suggestions welcome.
