Any setting suggestions? This rotates with pins in sockets. In case the image doesn’t work I attached a link to a google drive image.
Hi,
Does the part not print with those settings?
FWIW, I prefer more walls. I default to 3, but you may need more to ensure the pins are solid (for strength). I like cubic infill as the nozzle doesn’t cross over previous infill laid down like it does with grid so less chance of the nozzle catching and causing a layer shift. Grid infill is faster and many people use it. I think you can get away with few top/bottom layers. Try 5 or 4 ay a 0.2 mm layer height.
Works great now thanks!
