Anycubic Kobra Max. I used Pronterface to adjust PID for the bed and hot end. Adjusted eSteps. Ran the bed leveling. Using a 0.8 mm nozzle and a good quality filament.
Cura slicer default settings–except the nozzle was changed to 0.8 mm in the extruder tab. 0.6 mm layer height. Infill pattern is grid. Bed at 60 C and hot end at 195 C, very little to no stringing
It prints the bottom layers beautifully but when it gets to the infill walls the nozzle bumps into the perpendicular lines. It sounds like a train bumping over the tracks and I can see the nozzle contacting the infill walls/lines.
First printer so I am no expert, but from all the video’s I have watched everything looks beautiful until it starts the infill walls–specifically the first infill walls/lines that cross over the first lines it laid down.
I don’t actually know what where to adjust the z offset.
As a reference it runs all the infill lines in one direction, then does the diagonal direction and “bumps” into the existing lines where the circles are in the image below.
I tried reducing the infill layer height to 0.4 but that did not resolve the issue.
