I have a bunch of printing that I want to complete before Christmas, and I ended up making a spreadsheet to schedule it out.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:7140}[/ATTACH]
It’s pretty easy to use.
- Enter your typical changeover time at the top for cleaning the bed and changing filament.
- If you do automatic bed leveling before each print, enter the time that takes at the top.
- The spreadsheet calculates future start & completion times based on the "Print Hours" and actual "Start Time" you enter for the previous print.
- As you start prints, manually enter the actual "Start Time" and change the formatting to white (the formatting change isn't necessary--I just like to make manual entry cells white and formulas gray)
- You can change the order of future prints by doing right-click "Shift Down and Move". I used offset() functions in the calculated cells so that they continue to work correctly as you shuffle the future schedule.
Printing Schedule.xlsx.zip (9.21 KB)
