This post is about successful power loss print recovery after 15 minute outage. It includes information about hardware option of MKS PWC V3.0, it enables power loss monitoring, and power off when print complete. I purchased a PWC kit, for under $15, installed on Fokoos Odin-5 F3, and changed menu settings on MKS Robin Nano V1.2 control board via LCD. There is also a UPS board available that stores additional energy to raise Z axis, to keep nozzle out of print. With Marlin FW upgrade, both PWC and UPS are possible, but I have not tried that.
I am not associated MakerBase (MKS), but have a few printers with Robin Nano V1.2 control boards. Other manufacturers control boards, have similar power control options.
For power loss recovery to work, power fail must be detected, firmware must have capability to store layer index for restart, and sufficient residual power supply energy, to write layer index, to non volatile memory. When printer restarts, it loads failed job, with prefix start code, to preheat and home printer, do filament purge, then awaiting “start” by operator, to complete starting at failed point.
I have viewed a few printer reviews, and found reports of print recovery features, inoperative or buggy. Likely reason for this may be PWC needs to be installed, along with appropriate settings. Sales brochures, LCD menus and printed documentation for imported printers, often lack necessary information.
Shown below is a wiring diagram showing control board along with PWC, illuminated momentary control switch, power entry, and wiring. In my case power entry socket was same in my printer, so used it. Wiring was fairly short, but by placing momentary switch at back left side of enclosure, provided wiring worked without splices.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: H857e88370cef4def8071c79202176597m.webp Views: 0 Size: 74.1 KB ID: 16575”,“data-align”:“none”,“data-attachmentid”:“16575”,“data-size”:“full”}[/ATTACH]
In operation switch of power entry is turned on, momentary press of control switch bootstraps power control to printer control board. Printer can be set to “auto turn-off” in print job screen under “Options”, press “Manual” to toggle it to “Auto”. MakerBase has YouTube video on PWC installation here: MKS PWC tutorial with MKS Robin Nano - YouTube
My recovery experience was 100% successful, but it involved luck. Bed temperature dropped from 55C to 30C, quick preheat of bed kept print stuck to bed. I also preheated hotend prior to restart, since nozzle was stuck in print, that worked, also clipped small nub without disturbing print.
I have plans to purchase MKS UPS 24V and see if it will works to raise Z. I hope to post about that in future.
