Back story, recently, I had to replace the heat block, nozzle, heatbreak on my Ender 5.
As a result, while surfing, ran across a video explaining that you should do a PID auto tune in Marlin which is installed on my mainboard.
(Note of stupidity here: I did NOT save my existing PID values)
But the printer was working and I thought it might improve my prints on this unit which is dedicated to PETG.
So, we ran the autotune and saved the new values.
Now, we can’t print as the printer will show a thermal runaway shortly after the print starts after a layer or two.
After a bunch of trying to troubleshoot, and noticing that we had no problems while running Z probe wizard at PLA temps (which we ran after each teardown and check of the hotend), began to think the recent PID tuning might be a problem.
Long story short, because we ran across the idea that you should run the part cooling fan at 100% instead of the 0% that we had previously done, we ran the test again using the following commands.
m106 s255 ; Turn the part cooling fan on to 100%
m303 E0 S220 C10 U1 :Run the test and save the values based on a temp of 200°C
and to finish up make sure the parameters were saved (which they were)
OK, now the fun begins because being an ex engineer, ran the test again to see how close the results would be.
What a mess!
P I D
Run 1 69.37 13.34 90.19
Run 2 118.55 20.3 173.08
Run 3 48.84 5.36 111.36
Run 4 95.07 16.28 138.8
Run 5 72.21 11.88 109.76
Because the results between the first and second test were so wildly distributed, we ran more!
Based on these runs, I don’t trust any of them! A minor variation of the values could be expected, but these give me no confidence and would like some ideas on where to go from here! (Note:all test run same afternoon within about 2 hours)
One thought is to try the print that started throwing the thermal runaways with each of the above set of values:{(
But IF I can get a print to finish, actually how good are the values and how could I futher tweak them to make it better. Back around 2000, when I set the PID on servos for my cnc, I had a guideline to follow, but for a hotend, have no idea on how to go about it.
So some help for this ole guy from the group would be nice!
Country Bubba
