Well, I might have found my problem…
The under extrusion (or I feel in this case the mesh bed leveling results for the left side) was from the nozzle being a tiny bit to high causing the issue.
It was interesting that it only seemed to occur on the left side generally directly above the two left side bed leveling screws and then at a point in the middle of the bed on the left edge (and in line with the bed leveling screws on the left side).
The spacing was around 70mm apart which roughly corresponds to the circumference of the Y axis POM wheels.
I replaced the POM wheels and while the bed was torn apart replaced the yellow bed springs with silicon spacers. Two POM wheels had a good deal of wear so I was hoping I found the issue.
Ran a test and no change. Bummer
So I thunk on it some more. There may have been margaritas involved too. I came up with an thought. I use a 5 point bed mesh level. The first point checked is the front left corner then the hot end moves to the right for the rest of the first row measurements returning to the left in the second row and moves back to the third row (now the middle of the bed) and moves left again. And same scenario on the fourth and fifth row.
Ahhhhhh, the BL Touch probe is mounted to the left side of the hotend and when the hotend is to the left side of the bed the BL Touch ribbon cable is real close to the extruder motor (I use a Micro Swiss NG direct drive extruder and the motor is directly above the BL Touch).
I digress. I remember a couple years ago I was getting random beeps from the printer during printing. This was at the time a stock Ender 3 Pro. Googling indicated that wrapping the ribbon cable going between the mother board and LCD board with aluminum foil can fixed it. Apparently it was some electrical interference. And it did.
So I thought maybe the BL Touch ribbon cable is picking up interference from the extruder motor even though it is not extruding, but perhaps the motors are energized??
So I wrapped the first six inches or so of the ribbon cable in aluminum foil and ran another test. And the under extrusion is gone!!
Bonkers huh?
This is the hotend of the Ender 3 Pro showing the Micro Swiss NG extruder. The BL Touch is on the left. I print through a reverse Bowden tube from a dry box. The grey gizmo in front of the hotend cooling fan is a bracket for a dial caliper to tram the bed. Notice the Rube Goldberg contraption that the BL Touch ribbon cable is suspended on. When installing the NG I found if I strapped the BL Touch ribbon cable to the same wiring loom as the extruder motor cable the BL Touch would not work. So I made the zip tie stand-offs to hold it away from the cables.
You can see how close the BL Touch ribbon cable is to the NG motor.
Here the tin foil shield is installed. I found I needed to remove my propeller before it got knocked off by the cable. But it appears my under extrusion issue has abated.
So that’s my story of a self inflicted wound…
Larry
