Hi everybody, greetings from Holland.
Last month I bought the Ender 3 V2 from Creality. I find manually leveling the bed irritating so iI decided the install the Creality BL Touch.
I carefully watched the Dr Vax video’s severall times ans followed up the instructions.
The bed was four/five times manually leveled before the first print. The G-code of Creality Slicer 4.2 was adjusted with the code I found on this forum.
It looks like everything works as expected; but…
The prints are damaged and not like the ones I printed before installing the BL Touch.
I have printed this image several times with the same PLA and the same temperatures (200/60) before installing the BLTouch and they came out wonderfull.
In the picture you can see the print the way it comes out after installing BL Touch. At the front it looks OK but at the rear it is messy.
At the bottom of this topic is the G-code I used.
Can anyone help me to solve this problem ?
Robert.
G-code:
; Start EZABL startup gcode
M104 S150 ; set extruder temp
M140 S60 ; set bed temp
M190 S60 ; wait for bed temp
M117 Print Starting…
M75 ; Start Print Timer and Engage Fil Sensor if USB Printing
M84 E ; Disable E Motor for probe accuracy on direct drive systems
M117 Antiblob retract…
G92 E0 ; Reset Extruder distance to 0
G1 E-2 ; Retracts filament to prevent blobs during probing
M117 Homing All…
G28 ; home all axes
M117 Homing Z Probe…
G28 Z ; home z again
M117 Generating mesh…
G29; auto bed leveling
M117 Heaters Recovering…
G4 S10; wait for heaters to recover
M420 Z0; Z fade
M900 K0; LA
M117 Purging extruder…
G92 E0 ; reset extruder
G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
G1 X0.1 Y20 Z0.3 F5000.0 ; move to start-line position
M109 S200 ; wait for extruder temp
G1 X0.1 Y100.0 Z0.3 F500.0 E15 ; draw 1st line
G1 X0.4 Y100.0 Z0.3 F5000.0 ; move to side a little
G1 X0.4 Y20 Z0.3 F500.0 E30 ; draw 2nd line
M117 Printing…
; End EZABL startup code
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“full”,“title”:“1.jpg”,“data-attachmentid”:8975}[/ATTACH]
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“full”,“title”:“2.jpg”,“data-attachmentid”:8974}[/ATTACH]
