Fokoos Odin-5 F3 works great out of box, but extruder tension is tight for TPU.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: 20210526_154542.jpg Views: 10 Size: 92.4 KB ID: 15397”,“data-align”:“none”,“data-attachmentid”:“15397”,“data-size”:“medium”}[/ATTACH]
It is possible to add an adjustment screw, small plate, and lighter spring for adjustable tension. Idler frame ia already tapped for M4 screw.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG_20220602_102844.jpg Views: 5 Size: 118.1 KB ID: 15398”,“data-align”:“none”,“data-attachmentid”:“15398”,“data-size”:“medium”}[/ATTACH] [ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG_20220602_101348.jpg Views: 5 Size: 143.6 KB ID: 15399”,“data-align”:“none”,“data-attachmentid”:“15399”,“data-size”:“medium”}[/ATTACH] [ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG_20220602_102654.jpg Views: 5 Size: 115.8 KB ID: 15400”,“data-align”:“none”,“data-attachmentid”:“15400”,“data-size”:“medium”}[/ATTACH]
Original spring looks like a yellow bed spring but much smaller. It measures 15.7mm L, 7.7mm OD, compressed force of 2,200g.
I made spring using 0.9mm music wire. It has compression force of about 1000g.
My plan is to change out for TPU, as needed. It only takes 4 screws and a couple minutes.
