Hi,
This is my first post on this forum. It’s about a question that I have after following the YouTube tutorial of Irv regarding 3D printing basics. In that tutorial, Irv shows us how to remove material from a solid shape using the “Make a thick solid” button in Part Design:
[ATTACH=JSON]{“alt”:“Click image for larger version Name: MakeAThickSolid_Button.png Views: 0 Size: 1.3 KB ID: 16144”,“data-align”:“none”,“data-attachmentid”:“16144”,“data-size”:“full”,“title”:“MakeAThickSolid_Button.png”}[/ATTACH]
I’ve made something similar: a box to hook onto a DIN rail. However, that box has an “appendix” compared to the model shown in the video: a kind of “hook” to snap the box on the DIN rail:
[ATTACH=JSON]{“alt”:“Click image for larger version Name: din_rail_box.png Views: 0 Size: 74.0 KB ID: 16145”,“data-align”:“none”,“data-attachmentid”:“16145”,“data-size”:“full”,“title”:“din_rail_box.png”}[/ATTACH]
This is a screenshot taken from the Cura slicer. Mind the “hook” at the left of the model that is used to hang the box on the DIN rail.
My question: can the same technique be applied to take away the material, seen the fact there’s an “appendix” in the above model?
What I’ve done now is to select the top surface of the initial block and added a new sketch with a beam-alike shape which is a bit smaller than the initial model and then created a pocket and pushed the pocket downwards until I end up with a bottom thickness of 2mm. The result is perfect, but I’m not sure if this is the way a real 3D developer would do it.
Curious to hear what others think of this.
PS: If anyone is interested in the FreeCAD sources of the above, pls. let me know. I can share this with others.
Oops: forgot maybe the most important info…
Using FreeCAD 0.19 on a Windows 10 Home Edition machine
Best rgds,
–Aristide
