The left 2 photos are, as you can see, the actual lettering, which is printed separately from the tray, which has cutouts to hold the letters. The photo to the right is the first assembled one. I used Gorilla Micro Precision crazy glue to install the lettering. There are now 2 of them, and we’ll give them to her in the next few days.
It’s an Ender 5, so I don’t think wobble from a moving bed is an issue. However, I have noticed that the front of the bed can move slightly during a print, which is annoying. I call it vibration rather than wobble.
I wish I could just buy the complete Ender 5 Z axis sub-assembly, so I could mount it at the front of the printer and use it to stabilize the print bed. Short of that I found a pretty nice looking reinforcement technique on TV: [U]https://www.thingiverse.com/thing:4558463[/U]. All I have to do is get to Home Depot to buy some threaded rod and hex coupling nuts, then print the adapters. Hopefully, that would remove most of the vibration I see in during printing. At the moment, I take care to print everything as close to the back of the bed as possible, as near to the bed attachment point as I can.
It’s a stock Ender 5 except that I have converted it to semi-direct drive and relocated the filament spool holder. IOW, the print bed is unaltered. I know there are 3rd party ways to add a 2nd Z axis, but it would just be so much simpler to add a stock Z axis assembly.
Yes. I am aware that 2 Z stepper motors can be run from 1 Z stepper driver, although I suspect a MOSFET is needed to provide enough juice to drive both motors. I haven’t looked into it deeply, but I have found out that 2 Z connections on the control board are not needed.
One thing I wonder about is just how much difference it will actually make. I haven’t looked into that very deeply either.
I printed the slightly smaller version already 4 times. It basically has no back end. Prints way faster, less plastic and it is easier to get games in and out.
To be fair I printed a lot of Nintendo Switch accessory’s. Controller stands, Amiibo Wall Mounts and stands, GameCard case inlays to keep 10 games in one case. Colored grips for my ProController. A big grip for playing handheld, JoyCon Grips,
The last big project of mine was designing my own VR Headset for the Nintendo Switch. I now can watch 3D YouTube Videos and Play Zelda VR without even owning the original ToyCon VR Kit.
This looks quite like the forklift bed mount my TronXY X5 had. I added two rods and an additional lead screw, which I connected with the original one by a belt. It fixed all issues and prints are now great!
This stupid forklift design is ruining all benefits you gain from core xy.
Well, there isn´t additional load at all. The bed is still the same. Yes, it just got a few grams heavier do to the lead screw mount, the two bearings and some plastic. That is next to nothing.
The bed is no longer hanging and the bearings create far less friction as they did before, since the angled side forces are gone. In fact they now should cause nearly no friction at all. This alone should be enough to compensate for the additional weight of the new parts.
Since a belt is joining both lead screws, it works like one and the force gets shared equally. Instead of turning one rod it just turns two lead screws requiring basically the same energy as before. Just the little friction caused by the additional lead screw gets added to the mix.
To sum it up. I did nothing to compensate extra load as there is no extra load to compensate
It’s interesting that there’s an actual conversion kit. Did the belt come with the kit? I’m curious because I can’t imagine buying a length of belt and trying to join the ends together once the length is determined.
There was no kit. I just bought the identical rods and a lead screw plus the other stuff. I chose a belt which was a little longer than twice the distance of the lead screws. The closest I got was about 10cm longer than needed. The kit was just the printed parts to install them.
If you look onto the pictures I added to the link above, you see a large t-shaped object with one pulley at the tip. That is the tensioner. You loop the belt around the axis and then move the tensioner to one side until the belt it tight.
I saw the tensioner. It’s partly what made me wonder if the belt was already 1 piece when you got it: i.e. you didn’t have to try to join the ends of a length of belting.
It was a looped belt yes. I did once joined a belt using superglue. To be fair it worked quite well. I used it for prototyping the GeitPrinter and it never broke, which was surprising as it was on tension for over 8 month, before it got replaced along with a new z axis design.
The other parts I printed myself using the Anet A8. The parts look like shit, because of the size and the ANets print quality at the time, but it worked out fine. I have printed more than 200 hours without an issue related to the new dual z belt system. Beside that the prints look amazing
I hear you about prints looking like shit. People seem to want only pristine, beautiful prints, but they seem to forget that a print can be fully functional even if it’s less than perfect.
Superglue/Crazyglue to join the ends of a rubber belt together. I never would have guessed that would work. In fact, I would have predicted failure. Were the ends overlapped, or just butted together?
I usually don´t care about the look of my stuff. As mentioned in one other thread here at DrVax forums, I never used a printer specific profile. I basically use Cura defaults with some features turned on. Thats all.
In that kit print case the entire underside of the arm was lifted from bed, but I only had the ANet A8 at the time and got the TronXY X5 over local ebay for 120 Euro in a very bad but functional condition. I rebuild it from scratch and fixed the known issues, added a new power supply controlled by a Raspberry pi, added a RaspiCAM and LED, so I can see what is happening without having the light in the room turned on. I simply didn´t want to improve my ANET to end up with non working printer.
Once the TronXY X5 returned to the printing community with all its glory I gave the ANET a complete ABS overhaul, so it won´t melt when printing ABS inside its enclosure, which is what it is doing for over two years now. Just used it today printing the spool holder for my food dehydrator project.
Speaking of joining belts: Yeah, I overlapped the ends. I cut four teeth and some of the belt on one side off and removed next to all from the belt on the other side. Then I glued the parts together. It held like it was made that way. I even over tightened it in the end to see if it will fail, but it did not. The belt was to tight to be used, but it did not fail. I have it still in storage in case I need a looped belt for something.
It worked ok quality wise and for prototyping, but I think when printing one would have seen the z layers jumping every time a layer hits a pulley, cause it wasn´t perfect in thickness.
