Today I constructed the carboard filter box I mentioned earlier. I dug out a 140mm 12V fan and a 9V AC adapter. I decided I wanted a way to disconnect the AC adapter from the fan/filter box. I don’t have any barrel jacks so I looked around to find some way to create a wall jack I could install on the box. Since I’ve done so much Ethernet work over the years, I have quite a stock of RJ45 connectors & wall jacks, plus the tools to work them. I decided I would replace the default connector on the fan’s wires with an RJ45 jack, and mount that on the box. I would also replace the barrel connector on the AC adapter’s wire with an RJ45 plug.
I would attach the fan and RJ45 wall jack to 1 side of the box, and the furnace filter to the opposite side. All of the edges and corners would be sealed with packing tape.
So…
Here’s a photo of the side of the box with the fan and RJ45 wall jack:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:2112}[/ATTACH]
Here’s a closeup of the fan and wall jack. I plan to design & 3D print a grill to cover the fan:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:2114}[/ATTACH]
Here’s an overview of the filter side:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:2115}[/ATTACH]
And finally, here’s a closeup shot of the edge of the filter, in case anyone wants to buy the same kind.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:2116}[/ATTACH]
All in all, this filter box cost me only the price of the furnace filter. This is, after all, simply a proof of concept. Can an activated carbon furnace filter be used to remove filament fumes from the air? If it works, how well? I guess the next few days to weeks will provide an answer; at least I hope it will.
