Just for giggles, I printed a couple of items I don’t really need: a vase & an iris box.
I printed the vase to test what I can do with wood filament, and the iris box just to see if I could print it & have it work. The vase came out OK, but not perfect, and the iris box took some work after printing to get it working, but I did get it to work.
It’s Sunlu Wood filament. I’m not sure I would order it again, at least not without trying another brand. I found it was quite prone to stringing. Now, I’m not saying I had it dialed in as much as it could have been, but I had some post processing to do.
The iris boxes are impressive. I have always had trouble printing these without them sticking together. Never spent the time to fine-tune a printer sufficiently to make them perfect. I have been tempted to scale them up which will also scale up the clearances and make them easier to print.
Irv, the 1 I printed is actually designed to be a little stuck togerther after printing. It needs to be worked loose. It took a bit, and 1 of the iris leaves actually came loose & I had to use a small jack knife to get it back into place but, in the end, it works.
