Hi I made a research on the forum and I didn’t see anything, so I ask you, if you can help me,
I want to create some support like paint bottle rack, tool rack for insert in a pegboard, but I dont have any idea how create the different pegs, straight and curve or with angle, so I’ll wait for your comment.
You’re going to have to learn to use a CAD program such as FreeCAD or Fusion360. It will take you some time to get a handle on how they work, but it will help with all future designs.
Check the icons next to the pad one. The forth one in that section allows to extrude a sketch along a line.
So basically you draw a circle in a sketch on one face and a line defining the way this circle should be extruded in a second sketch. That is basically the kinda elbow shape, but just a continues line.
The other one is extruding though shapes, so you can turn a star shape into a circle, into a square into a circle by just creating multiple sketches with an offset in depth or orientation. This function is more complex, but would allow you to exit the plate using a square, while having the end a circle to make insertion easier.
If you hover the mouse over these tool bar buttons, they explain how they work and the UI is relative straight forward.
