In cura 4.8 printer settings, which initial settings works, I was using Wanhao Duplicator 6, is that the one to use? or should try Monoprice Ultimate 2?
Did not get answer to previous Post. does anybody know which
In cura 4.8 printer settings, which initial settings works, I was using Wanhao Duplicator 6, is that the one to use? or should try Monoprice Ultimate? Both work but skip bed leveling.
I tried new start code from reddit per Sami Heikkinen, It works but it skips bed leveling. and rapid move to start position. What is the G code for auto bed leveling?
At this point i will probably continue using cura 4.3 that came with machine.
I would like to be able to use some of the features in 4.8.
I’m a bit confused as well as to what you are asking. If you mean the Start G-code (“initial settings”), you can always make your own. One of DRVAX’s videos has generic g-code you could start with (I would think that one of his MP Ultimaker 2 videos has one as well.) If you have a good Start G-code in 4.3, just copy it over to 4.8. Did you try to import your U2 profile in 4.3 to 4.8? (I can’t remember which version changed profile variables, but Cura’s profiles are zip files and the text files within can easily be edited to make them compatible.)
If I change a nozzle or the hotend or the print bed, I’ll level the bed using manual to get close and then use auto leveling. I’m not sure why a printer would be so unstable as to require auto leveling before every print.
When I got my MU2 I did not understand How auto bed leveling worked. I previously had an Ender 2pro with manual bed leveling. I did not know you first had to level bed manually to start. I thought the auto leveling happened in the software. After watching Dr Vax video I realized and leveled bed. I do not level bed before every print. Bed leveling works fine.
I am going to copy start code from Cura 4.3 to 4.8.
Thanks
hello @Irv_Shapiro , i haven’t been here in a while. i had a question about bed leveling. what does it mean when the sensor moves to a spot and turns red? i have seen go to some spots but does not turn red.
