A little while ago I downloaded a cable strain relief model from thingiverse.com: [U]https://www.thingiverse.com/thing:726678[/U]. I printed the right angle version, as I couldn’t see much utility to the straight version.
It worked OK, but would pop off too easily, and I felt that the right angle being the bottom of the Surface was the wrong way. I decided to create my own remix, using much thinner walls and, of course, having the right angle at the top.
I printed 2: 1 for me & 1 for my wife, as we both have Surface Pro 5’s. I printed them early last night, and then installed them. My wife wasn’t thrilled with the original one, but she says this one definitely works better. And, she likes that I printed them in orange (instead of black) because she can see hers better.
Also, as with my previous project, I created it 1st in F360 and then tried to duplicate the design in FCAD. Both were successful. The FCAD design took longer, again because it lacks the little ‘helper’ features like automatically finding the midpoint of lines, dimensioning while drawing, easier to use offset planes, more versatile cutting capabilities, and much better filleting. Most of all, in F360 all the design features appeared as expected. As @Geit has pointed out, sometimes FCAD, due to what I consider a flaw in its rendering engine, causes features to be misplaced in a model. This happened to me on this model. When I went to cut the retangular hole for the LED on the connector, it cause the first cable retention ‘tunnel’ to be moved to the side of the model. It took a while, trying different techniques, to get both features in the proper place at the same time.
Here are a few image captures from F360 & FCAD, plus a photo of the finished product:
[ATTACH=JSON]{“alt”:“Click image for larger version Name: SurfacePro3-7strainRelief_F360_outside.jpg Views: 0 Size: 28.6 KB ID: 4859”,“data-align”:“none”,“data-attachmentid”:“4859”,“data-size”:“medium”}[/ATTACH] [ATTACH=JSON]{“alt”:“Click image for larger version Name: SurfacePro3-7strainRelief_F360_inside.jpg Views: 0 Size: 29.7 KB ID: 4858”,“data-align”:“none”,“data-attachmentid”:“4858”,“data-size”:“medium”}[/ATTACH]
These 2 are from F360
[ATTACH=JSON]{“alt”:“Click image for larger version Name: SurfacePro3-7strainRelief_FCAD_outside.jpg Views: 0 Size: 55.1 KB ID: 4860”,“data-align”:“none”,“data-attachmentid”:“4860”,“data-size”:“custom”,“height”:“214”,“width”:“430”}[/ATTACH] [ATTACH=JSON]{“alt”:“Click image for larger version Name: SurfacePro3-7strainRelief_FCAD_inside.jpg Views: 0 Size: 64.4 KB ID: 4861”,“data-align”:“none”,“data-attachmentid”:“4861”,“data-size”:“custom”,“height”:“213”,“width”:“429”}[/ATTACH]
These 2 are from FCAD
[ATTACH=JSON]{“alt”:“Click image for larger version Name: _MG_3592.jpg Views: 0 Size: 766.2 KB ID: 4862”,“data-align”:“none”,“data-attachmentid”:“4862”,“data-size”:“medium”}[/ATTACH]
Finished product (printed from F360 design)
The walls are 1 mm thick (instead of the 2.5 mm of the thingiverse.com model). This makes it much more flexible for inserting the connector and cable. The LED hole is a little larger so it’s easier to see.
