# Moon lamps
**URL:** https://forum.makewithtech.com/t/moon-lamps/2942
**Category:** Pictures of Your Builds
**Created:** [January 23, 2021, 5:34pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942 "2021-01-23T17:34:04Z")
**Posts on this page:** 20
**Page:** 1
<div class="post-metadata">
### Author: ![mochalatte](https://yyz1.discourse-cdn.com/flex035/user_avatar/forum.makewithtech.com/mochalatte/32/57_2.png) [@mochalatte](https://forum.makewithtech.com/u/mochalatte)
#### Post date: [January 23, 2021, 5:34pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/1 "2021-01-23T17:34:04Z")
</div>
I found these moon lithograph models and have been having great fun with them: [https://www.thingiverse.com/thing:4102658](https://www.thingiverse.com/thing:4102658). He provides several moon spheres ranging from 2 inch to 10 inch.
I started with the 3" moon and remeshed it to fit onto a night light I found on amazon:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:7870}[/ATTACH]
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:7871}[/ATTACH]
Note that these models are highly-detailed and it take a long time to remesh them. If I remember correctly, it took more than an hour to remesh that 3" ball to add my mount design.
And again, all that detail makes the print take time. That was about a 17 hour print.
 ![Screen Shot 2021-01-23 at 12.30.22 PM.png](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/7489a92db76b69d4fab5cfefc3793db7cbad9113.png)
 ![IMG_0457.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/385dbebfbb237299f89fec01e9e00bc1a8a6ccff.jpeg)
#### Post date: [January 23, 2021, 5:41pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/2 "2021-01-23T17:41:16Z")
</div>
Next I simply lowered the 5" moon on the build plate to leave a hole at the bottom for making this:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:7873}[/ATTACH]
The base also turns and changes colors. Video of it: [5inch moon lamp on Vimeo](https://vimeo.com/503856421)
 ![IMG_0458.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/8ad1be4e340182b8b7c56ec3de55d0f3dca25c86.jpeg)
#### Post date: [January 23, 2021, 5:53pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/3 "2021-01-23T17:53:30Z")
</div>
Next up is an 8 inch moon lamp that I will place in a tree in our back yard.
I designed a mount to hold the pendant light I bought. I split the model in half so that I don’t have to do any rewiring. I will epoxy this to the pendant light. I added a groove for a 60mm o-ring and pockets for 3/16" wooden dowels for alignment:
[ATTACH=JSON]{“alt”:“Click image for larger version Name: Screen Shot 2021-01-23 at 12.43.52 PM.png Views: 17 Size: 23.9 KB ID: 7875”,“data-align”:“none”,“data-attachmentid”:“7875”,“data-size”:“medium”}[/ATTACH]
Then I remeshed the 8" moon ball, which is the largest I can print on my 220x220x250mm Ender 3 V2, to include a mount. This remesh difference and union operations required to do this took 15 hours of FreeCAD processing time–not a typo!
[ATTACH=JSON]{“alt”:“Click image for larger version Name: Screen Shot 2021-01-23 at 12.45.23 PM.png Views: 14 Size: 258.5 KB ID: 7876”,“data-align”:“none”,“data-attachmentid”:“7876”,“data-size”:“medium”}[/ATTACH]
I’ve printed out the lamp holder pieces. The large hex nut is just a test print–the moon mount will eventually occupy that space.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG\_0455.jpeg Views: 14 Size: 3.59 MB ID: 7879”,“data-align”:“none”,“data-attachmentid”:“7879”,“data-size”:“medium”}[/ATTACH] [ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG\_0462.jpeg Views: 14 Size: 3.13 MB ID: 7878”,“data-align”:“none”,“data-attachmentid”:“7878”,“data-size”:“medium”}[/ATTACH]
And this is the overnight progress on printing the moon. Cura thinks it will be a 4day 21hour print, but they have been running long so this will probably be a full 5 day print. Printing in PETG since it will be be outside.
[ATTACH=JSON]{“alt”:“Click image for larger version Name: IMG\_0454.jpeg Views: 14 Size: 2.86 MB ID: 7877”,“data-align”:“none”,“data-attachmentid”:“7877”,“data-size”:“medium”}[/ATTACH]
![Screen Shot 2021-01-23 at 12.43.52 PM.png](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/672f4f97eeebbbdac653c3aca20adfab972c4a06.png)
 ![Screen Shot 2021-01-23 at 12.45.23 PM.png](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/827d61a09cf1031dce533103089a5bccaafdee7b.png)
 ![IMG_0454.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/66453a64807787a0e1cc4888fd18dbaa21ecf7a4.jpeg)
 ![IMG_0462.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/e9f774b6fe9673954993464e748d0972ae1abe49.jpeg)
 ![IMG_0455.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/2f11492fe7a7c6d281975b0887d0a4d154bd5606.jpeg)
### Author: ![Ender5r](https://avatars.discourse-cdn.com/v4/letter/e/b4bc9f/32.png) [@Ender5r](https://forum.makewithtech.com/u/Ender5r)
#### Post date: [January 23, 2021, 6:06pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/4 "2021-01-23T18:06:22Z")
</div>
An 8" moon globe in a tree. You are truly an evil man my friend. Just think how many birds, moths, & other critters you are going to completely confuse. They will completely lose their way around. 😃
### Author: ![roon4660](https://yyz1.discourse-cdn.com/flex035/user_avatar/forum.makewithtech.com/roon4660/32/35_2.png) [@roon4660](https://forum.makewithtech.com/u/roon4660)
#### Post date: [January 24, 2021, 12:21pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/5 "2021-01-24T12:21:07Z")
</div>
I remember 20 years ago when my son was studying 3d animation and trying to work on a windows pc that was already behind the times. I can remember the long rendering times. His friends couldn’t believe he could do 3d animation with that old computer at all. He gave it to me shortly after when he moved back to St. Barths.
I have always been amazed at how fast Cura and Prusa slicer can spit out g-code.
### Author: ![GrowFlavor](https://yyz1.discourse-cdn.com/flex035/user_avatar/forum.makewithtech.com/growflavor/32/94_2.png) [@GrowFlavor](https://forum.makewithtech.com/u/GrowFlavor)
#### Post date: [January 24, 2021, 12:51pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/6 "2021-01-24T12:51:52Z")
</div>
> [@mochalatte](#):
We would be grateful to know what profile settings (to make it easier, I could import & study your settings if you would be willing to make & share an export of a Cura profile with the settings) you used to get a successful print with these especially regarding having the top close properly. We have been using Cura to print parts of earlier versions of his Moon models in ‘Vase mode’ with the bottom set a few cm below the build plate then aborting the print when there is about a 5cm diameter hole left in the top of the ‘vase’ print version since that is where our Ender 5 starts printing in air…from other of our prints we speculate that our printer could successfully make bridges to close that hole but seem to not see Cura add bridge lines when we slice in non-vase mode so far…
And of course, very much looking forward to an update with how things go with your 5 day ‘outside Tree Moon’ print 🙂 Thanks!
 ![VaseModePartialMoon.jpg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/b65eb7fb67b97a0fb353a1ba79e493a4a48ae149.jpeg)
#### Post date: [January 24, 2021, 4:16pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/7 "2021-01-24T16:16:33Z")
</div>
> [@GrowFlavor](#):
Yeah, I have not been using vase mode since I want the lithograph image to work. As I’m sure you know, lithographs wouldn’t work in vase mode since modulating thickness of the shell is how the light & dark areas are created in the image.
I’m using the default “Dynamic Quality - 0.16mm” profile for Cura 4.7.1 with the only change being infill set at 100%. (I also made a permanent change to use inner walls flow of 90% for print-in-place articulating prints, which I don’t think has an impact for this print.). Again 100% infill is necessary for the lithograph to work properly. I wouldn’t mind attaching my Cura profile, but I don’t think it is worth it since those are the only two changes to the default profile that I used.
I hear you about that top portion of the ball printing in thin air. I am stunned that it works so well on my printer, but it has so far. The largest moon I’ve printed so far is the 6" and it closed up nicely at the top of the print without any stray strands. I haven’t had to do anything special. I would say, just try it and see if it works on your printer.
#### Post date: [January 24, 2021, 4:20pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/8 "2021-01-24T16:20:13Z")
</div>
1 thing to try would be to sink the model into the Cura print bed so only around an inch is left to print. This could be used to test how well the top fills in.
#### Post date: [January 24, 2021, 7:51pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/9 "2021-01-24T19:51:48Z")
</div>
> [@mochalatte](#):
> I’m using the default “Dynamic Quality - 0.16mm” profile for Cura 4.7.1 with the only change being infill set at 100%. .
Thanks, both of you, for your insights. The quick top test did complete. Also, are you using a 0.4 nozzle? (I’m tempted to experiment with a 0.6 for this globe…I’ll do another test top with the 0.6 since I’m using steel nozzles & with steel having different friction and about half the thermal conductivity of brass the flow is definitely different than with brass…especially with the glo filaments we use (its our default white filament since it costs the same.)
 ![TestMoonTop.JPG](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/203c5617b68c428da06fb65519c43a40a35fac0c.jpeg)
#### Post date: [January 24, 2021, 9:32pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/10 "2021-01-24T21:32:56Z")
</div>
Nice. Yeah, that looks similar to mine. I’m still printing with the stock 0.4mm nozzle that came with the printer when I got it at the beginning of October.
#### Post date: [January 25, 2021, 2:55am UTC](https://forum.makewithtech.com/t/moon-lamps/2942/11 "2021-01-25T02:55:57Z")
</div>
Well done. Glad to see the top test worked so well. It’s gotta give you some confidence when you go to print the full model.
#### Post date: [January 25, 2021, 3:56am UTC](https://forum.makewithtech.com/t/moon-lamps/2942/12 "2021-01-25T03:56:27Z")
</div>
> [@Ender5r](#):
Yep, that was a good idea.
#### Post date: [January 25, 2021, 11:39pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/13 "2021-01-25T23:39:52Z")
</div>
What is the standard cure for models that show empty spaces on the top pf domes or shoulders etc? So far I just increase top layer.
#### Post date: [January 29, 2021, 4:37am UTC](https://forum.makewithtech.com/t/moon-lamps/2942/14 "2021-01-29T04:37:36Z")
</div>
It came out really good. The 8" moon print ended up taking 4 days, 11 hours, and 42 minutes.
Cool to see so much of the print volume used:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:8034}[/ATTACH]
The main challenge ended up being all the stringing I had with this PETG. This is before I tried cleaning it off.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:8031}[/ATTACH]
A few minutes with some tools and duct tape got most of the hairy stings.
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:8035}[/ATTACH]
This photo shows some of the burned filament that tangled into the print:
[ATTACH=JSON]{“data-align”:“none”,“data-size”:“medium”,“data-attachmentid”:8030}[/ATTACH]
What was happening was the strings were slowly accumulating on the exterior of the hot nozzle and eventually got hot enough to burn. Sometimes those burned clumps got tangled into the print and became part of my moon. When I noticed what was happening, I put duct tape on the end of a stick and tried to gather up the strings every once in a while. It felt a bit like loading up a stick with freshly spun cotton candy. But obviously I couldn’t be there for all 107 hours of the print, so several ended up in the moon.
But other than a few burn marks, I’m really happy with how the print came out. I’ll just call those burns fresh craters.
 ![IMG_0477.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/c3cf3aa750d669cb40da62926a2fa77c90c0a8d7.jpeg)
 ![IMG_0474.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/7d9f825ccef615bfb739a2fd257e761b258f610b.jpeg)
 ![IMG_0475.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/34e31a01226837e92714b9a8d1f34fe7ed414492.jpeg)
 ![IMG_0470.jpeg](https://canada1.discourse-cdn.com/flex035/uploads/makewithtech/original/1X/2af439fa84f446f9ba8bccb88ffde3c756da198a.jpeg)
#### Post date: [January 29, 2021, 5:06am UTC](https://forum.makewithtech.com/t/moon-lamps/2942/15 "2021-01-29T05:06:17Z")
</div>
Looks really good, and is very impressive when lit from within. Thx for sharing it.
#### Post date: [January 29, 2021, 12:37pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/16 "2021-01-29T12:37:39Z")
</div>
A couple of years ago when I first got my ender 3 pro I printed a globe about 6 inch diameter which took about 36 hours to print and I was just getting up to go take a look at it and I heard a ball bounce on my kitchen floor where the printer was plugging away. It unglued just before finishing.
#### Post date: [January 29, 2021, 4:16pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/17 "2021-01-29T16:16:49Z")
</div>
I bet your 1st words were, “Well, don’t that just suck?!”. 😃
#### Post date: [January 29, 2021, 6:02pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/18 "2021-01-29T18:02:12Z")
</div>
It seems more humorous now than it did then.
#### Post date: [January 29, 2021, 6:58pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/19 "2021-01-29T18:58:42Z")
</div>
If I could, I think I would have seen about cutting it down and turning it into a nite lite or something else that could use what was left.
#### Post date: [January 29, 2021, 7:42pm UTC](https://forum.makewithtech.com/t/moon-lamps/2942/20 "2021-01-29T19:42:42Z")
</div>
I was going to do something with it, but I either tossed it or gave it to somebody. It doesn’t take me long to flood my little apartment with plastic doo-dads when people don’t visit like they used to. That is why I’m taking a break besides the fact that my brain is on strike for the moment and I would probably screw something up if I try to push myself too hard and actually do something.
[Next page](https://forum.makewithtech.com/t/moon-lamps/2942.md?page=2)
