Open Source and 3d Printing
  • Filter
  • Time
  • Show
Clear All
new posts
  • Vassili Finellis
    replied
    Have anyone of you guys tried to install Duet software on a SKR board?
  • Ender5r
    replied
    At one time I was well versed in command line operations, particularly in UNIX, & more especially on the 3B2/400: https://en.wikipedia.org/wiki/File:3...g_on_grass.jpg. The photo is from the Wikipedia article https://en.wikipedia.org/wiki/3B_series_computers.
    Once GUI interfaces became available, I was quite happy to migrate. After decades of long, laborious sessions at a keyboard, I was more than ready to move on to a mouse.
  • Geit
    replied
    Originally posted by Ender5r View Post
    For such a lazy guy, you went to a lot of trouble. Mind you, you only went to as much trouble as you had to
    The printers are in another room and I was able to flash the firmware of all printers without lifting my ass from the seat
    I also feel at home in shell. The up/download to my website could be done by directly pushing the file, but I have tools here, where uploading a file is just a click and downloading again with wget is just a simple command.
  • Ender5r
    replied
    I had forgotten about that post. For such a lazy guy, you went to a lot of trouble. Mind you, you only went to as much trouble as you had to
    And, indeed, there is at least 1 firmware updater for OP: https://plugins.octoprint.org/plugins/firmwareupdater/. I suspect it would be easier for most people.
  • Geit
    replied
    My printers do updates via USB, so I just log into the Raspberry Pi (the one also running OctoPrint) using SSH and use a shell command to flash the firmware.
    I guess there are tools to flash the firmware directly from OctoPrint, but I did not want to install plugins for that, when I already knew the shell command just works.
    Here I made a post for that:
    https://forum.drvax.com/forum/3d-pri...rmware-in-2020
  • Ender5r
    replied
    Geit, how do you do firmware upgrades without SD Card support? Can OctoPrint do it?
  • Geit
    replied
    Originally posted by RChicago View Post
    I am bringing up an older-ish thread but Irv or anyone...Is there an opinion about AstroPrint vs Octoprint? I like the web based printing, ie. uploading the gcode file to the "box" and being able to print without connection to the printer or SD card. I am just curious.
    I added cheap raspberry pi2 to all of my printers. It is just great to have a simple search engine within the web interface, so if you want to print something again. All remotely and feed back via browser and camera.
    I have no idea about AstroPrint, but OctoPrint has tons of plugins and gets frequently updates and I can recommend it. It even disabled SD card support on all of my printers, as I never use it and connecting an USB to a desktop computer is no fun, when dealing with more than one printer.
  • RChicago
    replied
    Originally posted by irvshapiro View Post
    Folks, I have used Octoprint extensively and I am a big fan. Just to clarify Octoprint is not a slicer or printer firmware. It is a standalone application that connects to your printer over the printer USB port and provides wifi and remote (with the appropriate plugin) access to send prints and control your 3d printer. Most users install it on a Raspberry Pi using the specialized OctoPi version. It does also run on any computer support Python but I really do not see the utility of using it on a desktop except maybe as a gcode terminal.
    Some of the confusion occurs because an earlier version of Octoprint had a version of Cura included and there are plugins that add slicers. I currently use support in both Cura and PrusaSlicer to send Gcode over wifi to Octoprint.
    In addition to providing a wifi front end Octoprint via plugins includes a range of tools to improve your 3d printing workflow. For example, it includes a multi-filament (muti-color) workflow for single color 3d printers that I have reviewed in one of my Youtube videos.
    Octoprint does have competitors. Astroprint offers a similar solution with the addition of a cloud/web-based modeling and slicing environment. Recently Creality started selling a $45 box called Creality Wifi Box for $45. I have two of the Creality boxes sitting on my back desk waiting for a review I am going to do on the channel.
    -Tq. (Go Cubbies, April 1st 2021.)
  • Ender5r
    replied
    I suspect you could use HIPS filament for supports. It prints 230C to 240C, but you need Limonene to dissolve it.
  • irvshapiro
    replied
  • Geit
    replied
    It would be nice to have that for ABS,
    Since I slice all parts 3mm over the build plate, so the full object is on a brim, which has zigzak supports on top. On top of the supports the actual part gets printed. Since the entire weight of the part is laying on the support, the bottom surface finish is not the best and more or less fused. And no. A raft is no option. It takes so long to print.
    This is the best solution for ABS printing I found so far and it provides 100% flat prints, even when a side bends up. I just need to sand the bottom area to get rid of the zigzak pattern. Water desolvable ABS would be nice, but I guess impossible. But maybe printing on the usual desolvable material would be possible.
  • Ender5r
    replied
    Even better when the slicer has the ability to use the default material except for the last 2mm to 3mm where the support contacts the model. Saves on expensive dissolvable filament and there's less mess to clean up.
  • Geit
    replied
    Yeah, I want to try such supports, too.
    Since you donĀ“t need any gaps between materials you should have perfectly clean and straight lines on huge overhangs and stuff like nut pockets are far easier to use.
  • Ender5r
    replied
    I have a JGMaker printer Pro version on order so when it shows up in January I will do a review. I am very excited to try out dissolvable supports.
    I have 1 on order too. Like you, I'm excited to see what can be done with dissolvable supports.
  • irvshapiro
    replied
Working...
